No bolts, so how do I unbolt .....
Discussion in 'Mechanics Garage' started by bagpipes, Jan 31, 2015.
  1. bagpipes
    bagpipes New Member
    Ontario GTA(ish)
    Newby here. (I did a search for related threads but to no avail)
    I need to remove the seat lock from a 1991 that is bolted behind the rear foot peg bracket. I've managed to expose the lock at the rear but there are no visible bolts (probably for obvious reasons)
    Any idea how I go about removing this or do I need to drill it. I figured I'd ask before I start drilling and regret it.
    Thanks for reading.
    With a nice fresh set of vice grips, you can usually get on the edge of what's left of the break off bolt and get it to loosen.
  3. bagpipes
    bagpipes New Member
    Ontario GTA(ish)
    At the risk of sounding stupid, are the bolts in the pic broken off then? I thought that may have happened but they appear to be too smooth.
  4. mello dude
    Romania
    What does it look like on the back side? -- -If it is a rivet, I might try grinding the head off and punch it through... -- Looks like a tough drill it job....
  5. bagpipes
    bagpipes New Member
    Ontario GTA(ish)
    Only thing visible .from the front side is the key hole. That's the back side after I pulled the foot peg bracket off.
  6. Allyance
    Allyance Member
    Germany
    East Bay, California
    Those look like clips that were pressed on, should be able to get thin screw driver between clip and lock an work it off, leaving the two posts intact.
  7. zoom-zoom
    zoom-zoom Member
    BC, Canada
    When I polished the foot peg brackets on my wife's 96 VFR and my old 97 VFR I struggled to get those bolts off as well. It was suggested to me that I use a dremmel tool with a cutoff wheel to cut a slot in the back of both bolts and you can then use a flathead screwdriver to loosen the bolts. Both my 4th gens those were threaded screws with some sort of tamper proof head on them. Once I finished polishing the brackets and put the helmet/seat lock back together I got a couple of Phillips head stainless screws that fit the threads and once tight I used a drill to round out the Phillips head on the screws to make them tamper proof once again. Worked perfectly and should you ever need to remove them again, you can do the same thing.
  8. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    I believe those bolts are designed in such a way that the head breaks off when they are tightened to a specific tension during the initial installation. This is done as a security measure so that once installed they can't be easily removed. You'll have to either drill them out or use an extracting bit to remove them.
  9. squirrelman
    Just look for the cable that attaches to the lock and PULL. Shouldn't be necessary to split the lock to access cable end above. :worked_till_5am:
  10. bagpipes
    bagpipes New Member
    Ontario GTA(ish)
    I need to remove it. The lock is punched and I have a new one to replace it so it has to come off.
    Thanks for all the suggestions. The top of the bolts are smooth but not flat so if the consensus is that they are threaded, I'll go the dremel route and cut a slot into them. I don't really care if I wreck it, I just don't want to damage the screw holes for when I put the new one on.
    Cheers, you've all been great.
  11. tinkerinWstuff
    Or
  12. DaHose
    DaHose New Member
    Napa, CA.
    I agree. Those look like shear bolts. You have to drill out the bolt heads and remove the remaining Bilt with some vice grips.
    Jose
  13. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    I have to say Tink, it looks like you have a very complete tool kit.
  14. bagpipes
    bagpipes New Member
    Ontario GTA(ish)
    Nice hammer
  15. bagpipes
    bagpipes New Member
    Ontario GTA(ish)
    Dremel did the job - no hammer required.
    Thanks for the suggestions and I'm glad I didn't start cutting or drilling. Drilling / e-z-out may have worked but the dremel was literally a 5 minute job including attaching the cut off wheel.
    You guys are a great help - enjoy the Superbowl and have a cold one on me.:drinkers:
  16. tinkerinWstuff
    Dude, what the hell?
    Just because a hammer isn't required doesn't mean it isn't still the right tool!
    Especially in reassembly
  17. karazy
    karazy New Member
    Halifax, Nova Scotia, Canada
    I'm confused. Are those hammers, or torque wrenches? ARGH...
