newb question about chain tension
Discussion in 'Mechanics Garage' started by whiteboyslo, Apr 10, 2008.
  1. whiteboyslo
    whiteboyslo New Member
    San Diego, CA
    when i bought my 6th gen (used at 12K miles), the chain was super loose. i got it home, put it on the center stand, and adjusted the tensions as shown in the owner's manual. that was a few months ago. checking my chain out again the other day, it's now just as loose as before if not more so.
    now, understand that i am very new to bikes so this question may seem really obvious to most of you: is this normal? do i just have to habitually tighten up the chain on the bike? how often should i be checking?
    if this isn't normal, what should i be looking at? do i possibly have a worn out chain and sprockets, or would it be something worse?
    Mike
  2. mello dude
    Chains over time do loosen up - so what you see is normal. When you adjust your chain - kick it into gear and pull on the tire so you are pulling the top part of the chain tight. Then check the chain slack on the bottom.
    Cant really say how often - maybe 3000 miles for adjustment. I lube the chain roughly 700 - 1200 miles so while I'm there its ez to check the adjustment since it takes a whole 10 seconds.
    While I'm at it heres some chain lube tips --
    http://vfrworld.com/forums/mechanics-garage/13765-chain-lubrication-beginner.html
    Good luck,
    MD
  3. grinder
    grinder New Member
    British Columbia, Canada
    One thing you might want to check. At 12K the chain probably needs replacing. If the guy who sold it to you had it very loose there is a good chance it wasn't maintained very well. Hard to explain in an email how to check the chain for replacement so I would recommend taking it to a bike shop and asking them to do a quick check.
  4. Kevin_70
    Kevin_70 New Member
    Diamond Springs, CA
    That was my first thought as well.
  5. flameface
    flameface New Member
    New England
    Make sure the clamp bolt for the eccentric adjuster is tightened to torque spec. It may be slipping if not tightened correctly. Also, when you adjust a chain, you have to rotate the wheel to find the tightest section of chain and perform the adjustment to get the desired amount of slack in that position. Everywhere else in the wheel's rotation the chain is going to be looser if it is a semi-worn chain and sprockets. They don't stretch evenly and sprockets don't wear evenly either (if its been neglected) 12K is a fairly long ways for a neglected chain. My two cents...
  6. RVFR
    Dude, so many variables here, hard to say, but in my experience adjusting a chain like every 500 miles isn't out of line, just depends on use, as in lube, riding style, how annal one is in how much slack you're concerned with being to much. Me? I check it at least every long ride say 300 miles more than likely It won't need one but on the average by 500 miles there's enough to be taken in. also in your case depends on the care it received, when a chain decides to go by by, it does it pretty quick, also notice tight and lose spots, a chain never wears out evenly. Ive had it like on a race track you'll be adjusting the chain almost every time out then on long rides maybe won't touch it for 700 just depends, is why you keep an eye on it. m luckily the VFR is the easiest machine to do a chain adjustment on ;)
  7. whiteboyslo
    San Diego, CA
    thanks guys. i think i'm gonna get it replace if nothing else just for the peace of mind. i'm getting ready to turn this into a 100+ mile/day commuter and i DON'T need any surprises.
    so, dare i ask, what's a good chain and sprocket brand and where can i get a good price?
    also, is this a DIY job for someone mechanically-inclined? any special tools involved?
    Mike
  8. Scubalong
  9. whiteboyslo
    San Diego, CA
    wow. that makes my head spin. but what i'm hearing is the OEM sprockets are as good as anything else, mainly because they're steel. replace them with the chain, then get a 'gold' chain. don't understand all the talk of 510,520, etc, and it sounds like more of a PITA than i want to deal with to install, so maybe i'll leave this one to the pros.
    Mike
  10. flameface
    New England
    You need a chain rivet tool to set the connecting link. Everything else is easy. I would swap out the sprockets and chain at home, then load the bike in a pick-up and bring it to the shop to have them set the link.
  11. nyteshades
    nyteshades New Member
    Tulsa, OK
    A 520 chain is a heavier chain than a 510. Steel sprockets last longer, alum sprockets are lighter but don't last as long.
  12. whiteboyslo
    San Diego, CA
    heavier = better longevity? looking to get maximum wear out of this guy. weight isn't an issue. is anything needed to run a 'heavier' chain? different sprockets?
    Mike
  13. RVFR
    Hmm, see no mention of the 530, as thats what it is. unless some one all ready swapped it, as far as chain brands go R&K, D-D are both good chains and agree go with OEM sprockets. Yep, you'll need a chain rivet press.
  14. mello dude
    No the thing with steel vs aluminum is the aluminum is a "softer" material and will wear out quicker. Replace the word "heavier" with
    "beefier". Yeah the higher the number the more the chain will weigh, but it is stronger too.
    For the moment stick with stock sprockets and a high quality 530 chain, DID or RK. Once its installed and you lube and adjust it on a regular basis, theres no reason it wont go 20K miles or better.
    Good luck,
    MD
  15. Scubalong
    Good advise
    I agree with mello dude
    I did the same to my bike at 12k miles, replaced the change with DID gold, and stock spocket. Now at 40k mile the change still good condition, But I think the spocket need to replace again.
  16. nyteshades
    Tulsa, OK
    heavier = beefier.....:biggrin:
