new to this and lost!!! help
Discussion in 'General VFR Discussions' started by klbrowz, Aug 17, 2015.
  1. klbrowz
    klbrowz New Member
    86 vfr 700 rear wheel bearings part # .. And possibly the #9 item part # from the diagram...new to this forum stuff..been looking on the internet but I keep finding all kind of crazy and different part numbers.
  2. stoshmonster
    stoshmonster New Member
    The brake rotor side rear wheel bearing OEM part number is 96150-63040-10 (part number 22)
    According to the info it's a standard 6304 sealed ball bearing. The UU bearing suffix designation simply denotes that this bearing has a dust seal on both sides of the bearing.
    The drive sprocket side rear wheel bearing OEM part number is 96150-62040-10 (part number 23)
    According to the info it's a standard 6204 sealed ball bearing,same UU bearing suffix.
    The sprocket carrier hub bearing OEM part number is 96150-63050-10 (part number 24)
    According to the info it's a standard 6305 ball bearing. If you're replacing your rear wheel bearings it's a good idea to replace this bearing as well.
    No idea what part number 9 you're asking about Klbrowz as you didn't post up a pic in your original post.
    I can tell you that part number 9 in the parts breakdown pic that I've attached below is the rear wheel bearing spacer tube.
    It has no part number listed which denotes that the part is no longer available.
