New Owner Questions: 2004 VFR
Discussion in 'General VFR Discussions' started by rvmiller, Jul 1, 2012.
  1. rvmiller
    rvmiller New Member
    Tampa, FL
    I just bought a 2004 VFR and I do not have an owner's manual. I do have a Service manual that I was able to download though but it does not answer all my questions.
    1. How do you set the clock?
    2. On the left side of the Tach, what does "Air" represent... the tires?? (Coool!!!)
    3. How difficult is it to change the rear brake pads?
    This is my third bike but my 1st Honda but this by far is my best bike yet!!
    Thanks for any/all help
    Rob in Tampa, FL
  2. rvmiller
    rvmiller New Member
    Tampa, FL
    2012-06-28 05.31.29.jpg my bike - Rob in tampa
  3. Scubalong
    To adjust the clock yurn on the ignition press the two square button unfilled the clock blink
    Press the left button to adjust the hour repeat step one for minutes
    The air temp is for the the actual air weather not ur tires
  4. Scubalong
    Rear brake pad Will take about two beers
  5. Scubalong
    Do you need step by step instruction?
    Let me finish my beer and get back with the instruction
  6. TOE CUTTER
    Lol, two beers if your milking it.
  7. TOE CUTTER
    Air is the ambient temp, you can chenge it from that to engine temp by pushing the rubber button next to it.
  8. Scubalong
    I do like my beers so why hurry especially good micro brew
  9. rvmiller
    rvmiller New Member
    Tampa, FL
    i got the clock set to the correct time and yes, I'll take all the help I can get on changing my rear brakes
  10. rvmiller
    rvmiller New Member
    Tampa, FL
    Thanks for the answer to the "Air" question also.
    Rob in Tampa
    P.S. "Toe Cutter"... aint that a 'Mad Max reference??
  11. Scubalong
    suppose to be but he did got his finger cut off though
