New owner of a vf-750
Discussion in '1st & 2nd Generation 1983-1989' started by shdybrady, Nov 30, 2010.
  1. shdybrady
    shdybrady New Member
    My uncle decided to give away his 1983 vf-750f. He bought it to tinker with and ride but found out he didnt have enough time. I did a nice jester to him in the past and he decided to return the favor and give it to me. He said he thinks the head gasket needs to be replaced. He had it running and some white smoke came out and there was some water in the oil. Sounds like a head gasket to me. Is this a common problem? Also is there any thing that I should address about it? I have owned to suzuki 750's and this is my first honda. Any help would be appreciated
  2. tinkerinWstuff
    congrats on your new gift. sounds like the price was right :thumbsup:
    Sounds like a compression test followed by a leakdown test may be in order to determine what is really going on inside that puppy. You can use google to find instructions on both if you are not familiar. I'm guessing that thing hasn't been run for quite some time so you might start by cleaning the tank and getting some seafoam in the carbs. Never know, if you have the time to let stuff soak for a couple weeks then you might get lucky and not have to pull the carbs - unless of course you have headgasket problems.....
    How about some pics of this new project?
    :worthless:
  3. shdybrady
    Ill be sure to do those. I will essentially check everything as I go. The funny thing is, I dont even have the bike yet. I go to pick it up this weekend
  4. squirrelman
    Save yourself the expense and frustration: this will probably never be a good-running bike again.
  5. Dragone19
    Dragone19 New Member
    Why's that? Was that an invitation for him to give it to me?
    Congrats on the new ride.
  6. tinkerinWstuff
    The first generation V4's had some problems and parts are becoming more difficult to find. Squirrel particularly dislikes them. If you hadn't got it as a free gift from a family member then I'd be on the squirrel-wagon too.
    But, since you snagged it for free, it's worth checking out. Who knows, you could have a real gem there. Too early to tell without some basic diagnostic tests to see what you have. Just don't go out there buying shit and spending money on the thing until you know you have something worth investing in. (i.e. don't go buying tires, body parts, etc...)
    First you'll need to figure out whether there's compression or not
    if not, the leak down test to see it it's a valve issue or head gasket
    then there's carb cleaning
    potential bad cams (design flaw in 1st gen)
    and finally potential ignition system difficulties.
    really no different story than any other 25yr old bike. Too early in this one to be discouraged or excited. Just proceed cautiously with your wallet and have fun.
  7. Dragone19
    Thanks for that info. Being a new Honda owner that makes sense.
    I agree with going to the basics of troubleshooting and checks as well.
    Congrats again on the new ride.
  8. TOE CUTTER
    Squirrel is in love with gen 1 and in time will come to grips with it. I for one say pull both heads and inpect. Just got bit on the ass by a gen 1 that looked good and passed leak down test but had a bad spot in the bore due to corrosion from sitting. Given the known problem pulling the heads and inspecting is the best path in my opinion.
  9. shdybrady
    I will definetely give it a all around inspection. And it only makes since to make sure the bike is running before buying cosmetics or anything. I cant wait to get it this weekend and give a quick run through and see whats going on. Great thing about it my uncle is pretty good with motors and mechanics. So Ill get the list of what he has done and reinspect it all. Just as a quick note. How much are these things selling for?
  10. Dragone19
    So Honda has an issue again but this time with their process in plating? hmm, I am not feeling all "warm and fuzzy" the more I read about the VFR.
  11. tinkerinWstuff
    I believe TOE was referring to the OP's statement about white smoke and water in crankcase? unless I missed something else. I'm not aware of problems with cylinder wall design or manufacture.
    And there is no problem with "VFR"s only the "VF"
  12. 34468 Randy
    Welcome to the forum. I wished I could offer you sound advice on your ills but I can't. Toe and Tunk are great sources here so listen to what they have to say. I am sure there are many others as well.
    Post up some pix when you can. We all get orgasmic over good pix.
  13. Pcohen
    Pcohen New Member
    jonesboro, arkansas
    The first gen problems arent quite as bad as ppl make them out to be IMHO. Most of them were resolved by 83' anyways. I've got a 1st gen with 56k miles on it :cool: I think the main problem with 1st gens is that they have been molested by PO's. I've owned 4 VF's and only had problems out of one of them (a 500) and that was mainly my fault.
    While you have the motor out and heads off it would be a good idea to replace the cam chain tensioners. Get the carbs freshened up and as long as the cam lobes arent flat and nothing is bad out of place you shouldn't really have too many probs with it. Do a valve adjustment while your at it too. You will run into little stuff here and there like you would on any old machine. I love projects like this and since this was a free bike you dont have much to loose!
    Good luck!
  14. shdybrady
    Man I'm all hyped up about it. I was going to get it and sale it, but that might just change after I get it running
  15. shdybrady
    Im sure Im jumping the gun, but I like to learn as much as I can before I tear into a bike/car. But every car I have owned there have been some kind of free or cheap mods. Is there any known ones for these bikes? Maybe forks or brakes from later years. different plastics. Again, first priority is getting it running. I just want to see whats out there
  16. hopit88
    hopit88 New Member
    I would love to get my hands on a free V45 Interceptor, trashed cams or not. ANYTHING can be fixed with time and money. There's quitters and doer's. Doer's bring bikes/cars back from the dead, quitters don't. If it weren't for quitters, doers would have a hard time finding projects, so we really should be thankful for those who are easily frightened. If it looks like a lost cause, pass it along to someone else. Some issues can't be addressed by everyone. Some lack talent, some lack tools or space or time or money. If it's too much, try to give it away as a whole bike. The trouble with parting it is, after the choice parts are gone many are left with a half complete bike that just gets tossed in the dump and that's a waste.They should be repaired not junked. Can't wait to see how you make out. Keep us posted.
  17. invisible cities
    invisible cities New Member
    new york
    +1, nicely written Hop.
    Owing a vintage bike isn't for everyone but for those who enjoy the challenge they are great projects and can be very rewarding to work on.
    On this note, Tink's posts above are on the mark as well. Diagnose the issues first. Mr. Tink has a great deal of working knowledge and can be very helpful,,,even if he is ever so slightly disappointed in the engineering on First Generation V-Four engines.
  18. hopit88
    hopit88 New Member
    +1... agree on both points.
  19. rc24rc51
    rc24rc51 New Member
    Liberty SC
    to be fair you mean VF. we should really be calling this site InterceptorWorld.com VFRs are not problematic at all.
  20. Alaskan
    Alaskan Member
    Alaska
    Welcome to ownership of a 1st Gen. If you aren't crazy yet, you soon will be! :)
    Head gasket blew also on my 1984 VF750F, but I don't know how common that is.
    I am no expert, but I was able to replace the head gasket on mine. A Honda shop manual is a must. The Clymer has some errors on valve timing.
    There is considerable expertise here on these old VFs. masonv45 has been very helpful to me. Jamie Daugherty too. Lots of others as well.
    Good luck.
