New member - first post!
Discussion in 'Introductions' started by greenyogi8, Aug 21, 2008.
  1. greenyogi8
    greenyogi8 New Member
    Westerly, RI
    Hi Everyone,
    I must admit that I joined in the hopes I can find some repair suggestions.
    After going about 5 years w/o a bike, I just bought an '86 750F model with only 19K. It's in very good shape - all original, even the exhaust! I put on new tires (Dunlop stock sizes), had the shop do an overall check and test drive and have ridden about 600 miles since.
    I just lost clutch pressure - there is wayyy too much lever movement before clutch engages, and when it does, it seems like it is all or nothing - not gradual like it is supposed to be. This happened last night. There was a little smoke from the area of the front sprocket and only about 4-5 drops of fluid made it to the ground. Has anyne had similar problems or does anyone have any ideas? I know that I have to find and repair the leak, but is this a known problem with VFRs like the rectifier-type of known issue?
    Any help is appreciated!!
  2. VFRShorty
    VFRShorty New Member
    NW Oregon
    Welcome to the site, greeny!! I can't help out with that clutch problem, but I can make sure you feel weclome! :wave:
  3. fotodaddy
    fotodaddy New Member
    Lagos, Nigeria.
    Hello Greenie!!! Welcome!!! I am also new here but have had quite some experience with bikes. From the sound of it, and the age of the bike, I would think you should take it bake to the repair shop. You have probably worn down the lower clutch cylinder so that everytime you pull the lever, fluid just passes by the piston seals. I think its a fairly complex procedure (if you are not the techie type) so my suggestion above.
    All the best
  4. elf800
    elf800 Banned
    dallas
    low fluid? old fluid? old lines leaking? can't tell but the honda shop sounds like a great place to get it fixed right good luck and don't drop the soap.. muhuhuhuhhahahahahhaa
