New Interceptor 500 in Central WI
Discussion in 'Introductions' started by Zman87gt, Mar 22, 2010.
  1. Zman87gt
    Zman87gt New Member
    So hello everyone. My name is Zack and I'm becoming a pretty big Honda nut. It started last fall with an 86 200x trike. Now my garage currently has a new 08 700xx quad, an 02 250ex quad, an 86 350x trike, and a 1984 Interceptor 500 (newest toy). So the bike was given to me from my wife's cousin's Husband. It needs some work but I have had it running and drove it a couple miles. It has an aftermarket fuel pump that seems to work after I beat on it. I'll probably set it up as a gravity feed system anyway. Also the carbs are leaking pretty good out of the float bowls. I am alittle nervous doing the carbs myself. The water pump is also starting to leak a little as well. So with a little work I should have a neat little bike to play with. Someone also painted it at some time and added a full fearing on it. once I get it running good I want to have it repainted black and add red honda decals to it. Anyway, I'm sure I will be searching through the forums looking for tips and stuff on this bike. Thanks in advance for the helpful resource and community!
    - Zack
  2. tinkerinWstuff
    Making that thing reliable again will keep you out of the bars!
    Welcome to the forum - lots of good info if you scan thru the 1st gen forum.
    Where 'bouts in WI? I lived and still have property in Cumberland.
