New guy VFR won't start
Discussion in '3rd & 4th Generation 1990-1997' started by BugsyK, Nov 12, 2016.
  1. BugsyK
    BugsyK New Member
    My apologies if this is a common problem. I've had my 96 VFR for about 2 years it has 18000 miles. It has been running great but about 6 months ago I would have to hit the start button a couple times before it would do anything. I haven't ridden it in about a month and did an oil change yesterday. Tried to start it and it turned over but wouldn't start. The battery was weak so I charged it. Now when I hit the start button I get nothing. Lights dim but it doesn't even click.
  2. duccmann
    How old is the battery? My OEM lasted 5 years---
    Think you should take it to a local auto parts store and have it load tested.
    May be time
  3. BugsyK
    BugsyK New Member
    I've had the bike for a couple years and don't know when the previous owner purchased the battery. She said she always kept it on a battery tender. It indicates fully charged but it's not a bad idea to have it load tested.
  4. TOE CUTTER
    Do you have a meter? What is the standing voltage at the battery and what is it when you hit the starter button?
  5. BugsyK
    BugsyK New Member
    I don't have a meter.
  6. BugsyK
    BugsyK New Member
    Well, went out this morning and it fired right up first try. Hmmm...
  7. RVFR
    I was going to say the same thing as Duc and Toe, still agree, the battery should be checked to take any questions outa of the thought. then theres the switch, and or the relay as well, but check the battery, a resting battery will slightly charge once drained, but only a bit, the other thing here is do a load test. I've seen battery's with good voltage, but have next to noting when they're called in to do their thing equals No cranking amps.
  8. BugsyK
    BugsyK New Member
    Thanks, I'll definitely have the battery checked out.
  9. TOE CUTTER
  10. duccmann
    Toe, think I just may head ta Sears--- thanks
  11. BugsyK
    BugsyK New Member
    Yeah, thanks for the info. I'll check out Sears.
