New clutch
Discussion in '5th Generation 1998-2001' started by Andrew_rc46, Feb 15, 2014.
  1. Andrew_rc46
    Andrew_rc46 New Member
    North yorkshire
    New clutch fitted today, ebc clutch plates and ebb stiffer springs,gasket k&n oil filter and oil change
  2. VFR_AG
    VFR_AG New Member
    How was it to do the upgrade ? How many miles ?
  3. Andrew_rc46
    North yorkshire
    The old girl has done 27k, tbh it was a pain1 the haynes manual doesn't tell you the the clutch spring bolts are one time use only (i found out the hard way) plus you need a torque wrench thats does 9lbft and up (this i has to buy @ £39).
    But once all was in place the job was a breeze, and it feels much better in the hand.
  4. don1163
    don1163 New Member
    Somerset UK
    Clutch spring bolts aren't one time use only, you just did them up too tight without using a torque wrench... The bolts snap quite easily, as you now know ...
  5. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    I just think they stretch over time, I had the same problem when I replaced my clutch at 62000k's.
    It didn't get any where near torque setting before 2 broke. When I looked at the remaining ones, they were all stretched
    At least it was easy to remove brocken bits, I replaced the lot with new high tensile ones.
  6. Andrew_rc46
    North yorkshire
    That's exactly what i did, I went to the expense of a tap set with extractor, when I started to drill the one that had snapped, it started to screw in! So I put the drill into reverse and screwed it out! I was like "please come out without doing any real damage" the clutch was completely buggered, but my friends tell me that the bike was never designed to do what I do to it lol.
