New brake/clutch lines
Discussion in '1st & 2nd Generation 1983-1989' started by Prime Target, Dec 23, 2025 at 11:24 AM.
  1. Prime Target
    Prime Target New Member
    Myrtle Beach, South Carolina
    Hello all and Merry Christmas. After the Christmas holiday passes, I'm going to start refurbishing the brakes on my 86 700. I'm planning on using Spiegler S/S lines to replace the original lines. Trying to decide if I should install a 2-line system on the front with a double line banjo bolt on the master or go with the original design 3-line style with the T fitting and single line banjo bolt on the master. My 87 has a 2-line S/S system for the front lines that my brother installed a few years back. not sure which setup works better. Opinions?
  2. jkboyd
    jkboyd Insider
    Havre de Grace, MD
    Hi, I'm not sure if one is better than the other but I installed the black Galfer two line kit on my 86 VFR. I like it.
    Prime Target likes this.
    They will "work" the same. A properly bled 3-line system will function exactly the same as a 2-line.
    Less parts, lower cost potential, routing, "originality" will be the driving factors. On some bikes, a double banjo at the master can create potential clearance issues (see VF1000R), but the VFR700/750F is not one of them.
  4. jkboyd
    jkboyd Insider
    Havre de Grace, MD
    That's true Capt., I've have had clearance issues with a double bango on other bikes. It worked out fine on the 86. I have a three line setup on my 00 VFR and don't notice any difference between it and a two line system. I'd go with the cheaper setup. Lol
  5. Prime Target
    Thanks for the replies fellas. I decided to go with the 2-line setup like I have on the 87.
    jkboyd likes this.
