New bike
Discussion in '3rd & 4th Generation 1990-1997' started by Toozna8, May 6, 2010.
  1. Toozna8
    Toozna8 New Member
    Okay so I just bought a beautiful 92 vfr. I have had no problems with it except for when i'm filling out the info for the title. Maybe I'm just oblivious but I cannot find the damn engine number anywhere. I've looked all over the engine block and it is nowhere. Anybody know where I can find that thing so I can get her licensed and on the road?
  2. afpierce489
    afpierce489 New Member
    Cape Cod, MA
    First off, welcome to the madness. Post up some pics when you get the chance. Second, the frame serial number is stamped into the right side of the steering head, and is also stamped on the identification plate attached to the right side of the frame. The engine serial number is stamped into the right upper side of the crankcase, directly above the clutch unit. Good luck.
  3. tinkerinWstuff
    right side, above the clutch and at the base of the #3 cylinder.
  4. crustyrider
    crustyrider New Member
    North Country, New York
    :worthless:
  5. drewl
    drewl Insider
    Virginia Beach, Va
    Welcome aboard.
  6. MrDen
    MrDen New Member
    Maricopa, AZ
    welcome to the madness that is the vfr addiction...
  7. RVFR
    What they said.. Yea, where's the photos?
  8. cebuVFR
    cebuVFR Member
    Carson,CA
    Welcome Aboard! You need to remove the seat and its under the right side of the tank.
  9. Toozna8
    Toozna8 New Member
    Wow thanks for the responses and I'll try to get some pics up when I get a chance. Do I need to remove anything to find the engine serial number (fairing, gas tank, etc?). Any other bike I see has the engine number stamped right there in plain sight. Buuuut I suppose this is a small issue to have for a bike so I consider myself lucky!
