Need wiring dia for 85 VF1000R
Discussion in '1st & 2nd Generation 1983-1989' started by GreyVF750F, Nov 21, 2012.
  1. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    I need a wiring diagram for a 85 VF1000R, basically for the gauge panel. I just got a full fairing and gauge panel from a 85 VF1000R that I'm going to put on my 83 750. I'd like to use the R gauge panel. I need to check the wiring to see if I can plug n play or see what modifications are needed to adapt the wiring to my bikes connectors. This will be my winter project. I also will need a fuel gauge that will work with my tank sensor seeing the 750's fuel gauge is part of the gauge cluster that I'm taking off and the R doesn't have one. Any ideas there?
  2. karazy
    karazy New Member
    Halifax, Nova Scotia, Canada
  3. GreyVF750F
    GreyVF750F Member
  4. karazy
    karazy New Member
  5. GreyVF750F
    GreyVF750F Member
    That's a start though its hard to read. I saved it and enlarged it and it was worse. But it's better than what I have (nothing) Thanks
  6. karazy
    karazy New Member
    Maybe you can use it to compare with the F model diagram and work off it.
  7. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    I have full sized hard copies from 2 different Honda shop manuals, one 8 1/2" x 11" and one 11" x 17". I can scan them this weekend and email or post. In jpg or pdf they're going to be large files. PM me an email if you want them.
