Need some simple help guys
Discussion in 'General VFR Discussions' started by hybrid, Apr 23, 2008.
  1. hybrid
    hybrid New Member
    I have a custom job Im doing, need to know the distance from outside edge to outside edge of the front brake rotors, diameter and thickness of the rotors for 5th gen and 6th gen VFR
    Also, does the back wheel bolt right up to the 750 arm?
    The reason I ask this of you is that Im converting to a single arm and want the wheels to match on a kawasaki I have here.
    Any solid well measured information would be highly and greatly appreciated. Id like to not spend several hundred dollars to find it wont fit.
  2. safetypro10
    safetypro10 New Member
    Dallas, TX
    Custom
    Don't know on the front, but the back wheel from a 5th will require clearancing over the brake rotor bolt heads on the 3rd gen swingarm to bolt up flat.
    Larry
  3. hybrid
    hybrid New Member
    thanks for the heads up. So long as I can stick it on the previous arms bolt pattern hub I can do the rest.
