Need some advice
Discussion in '3rd & 4th Generation 1990-1997' started by thorrinn123, Jun 16, 2008.
  1. thorrinn123
    thorrinn123 New Member
    I want to get myself a VFR again and I have found one a 91 with 49000kms or about 30000 miles been serviced regularly has a new front tire , new front sprocket, and new chain on it.....he is asking 2900 CDN is this a good deal with that high of mileage?
  2. derstuka
    San Diego, CA
    30k is nothing at all a for a properly maintained VFR. Those V4 motors were built to last. Seen quite a few with over 100k. I paid $4600 for my '98 with 24K miles on it. If the bike is in good condition and serviced regularly as you say, I would think it might be worth $2900. I would still offer him a few hundred less in cash to see if he takes it.
  3. thorrinn123
    thanks for the reply i will see what he says....if i get it i probably will take it in to get serviced and oil changed...for piece of mind.
  4. old450
    old450 New Member
    Ontario
    FWIW
    I picked up a 91 with 53000km on it this spring. Needed a new chain and sprockets, I also replaced the R/R with a used GSXR unit. I paid 2500CDN for it. With the upgrades I have it on the road for 2750 + my labour.
    Good Luck
  5. thorrinn123
    cool, i have heard alot about this R/R is this something i should just replace...and where can one get one? Is this something you can do yourself?
  6. toillbaill
    toillbaill New Member
    you can get one at your local bike shop, off ebay or wherever. doesn't really need replacing if it works. if you do have to replace it its an easy fix, takes about ten minutes and anybody can do it. when i bought mine it had the original R/R, but with a cpu-fan mounted. seems to keep it cool enough.
