need pics of r/r relay wires from 96 vfr
Discussion in 'Mechanics Garage' started by hurst96vfr, Nov 15, 2010.
  1. hurst96vfr
    hurst96vfr New Member
    pensacola fl ,soon to be san antonio tx
    ok i had got the wires on the relay mixed up while i was cleaning and replacing the terminals and it burned up my r/r now i got a new r/r , and i think the wires are still mixed up and i dont want to burn this one up so could somebody post a clear pic of their 1994-1997 vfr starter relay with the wires so i can get my wire colors correct , thanks and also the 3 yellow wires going to the r/r does it matter if they get mixed up or are they all pretty much the same?thanks guys
  2. tinkerinWstuff
    three yellow wires don't matter. Otherwise they would have color coded them. It's 3 phase alternating current and how the phase is doesn't matter.
    There should be photos in your factory service manual. I know there are for the R/R connection.
  3. tinkerinWstuff
  4. tinkerinWstuff
  5. hurst96vfr
    well thats good to know bout the 3 yellow wires, Now i just need a pic of theactual starter relay with the wires still hoked up so i can tell which one is which, and i do have a service manual and it shows the wire colors but it does not show in which order they hook up i just need a visual pic so i know for sure thanks guys
  6. karazy
    karazy New Member
    Halifax, Nova Scotia, Canada
  7. hurst96vfr
    well i got the wires hooked up best from what i could see in that pic, though i do wish i had a better pic to be sure, and my r/r is getting really hot is that normal? i would hate to burn this new one up i just got?
  8. tinkerinWstuff
    if everything ohm checks out in accordance with the tests outlined in the factory service manual, then you should be fine. Some heat on the R/R is normal. Hopefully you've inspected the stator to harness plug on the right side of the bike.
  9. karazy
    karazy New Member
    Running hot is normal, more so if the bike is not moving. A few people have installed a computer fan to it, for good measure. I picked one up for this reason, but have not installed it yet. I am still on the original R/R and have not had any problems, so far. knock knock
  10. hurst96vfr
    hey KARAZY could you post a good pic of your wires going to your starter relay so i can be double sure i got mine hooked up right i would appreciate it so very much but if not its cool
  11. karazy
    karazy New Member
  12. hurst96vfr
    thanks a lot thos pics were exactly what i needed thanks tons and happy riding
