need PC 5 map for 2012 or 2013 VFR1200F
Discussion in '7th Generation 2010-Present' started by dynajohn, Sep 21, 2013.
  1. dynajohn
    dynajohn New Member
    KY
    Any body have a PC5 map (stock bike or slip on) for a 2012 or 2013 VFR 1200F?? Nothing listed on DJ website for the 2012 & 2013 bike. I assume since they changed the ECU software on the 2012 it would take a different map.
  2. cornerexit
    cornerexit New Member
    I wouldn't use someone elses map unless it's from your same elevation and geographic area. Best thing for the motor is to run an autotune module as it will compensate for atmospheric conditions.
  3. dynajohn
    dynajohn New Member
    KY
    I was originally hesitant about using the DJ auto tune module but am rethinking that option. Only $209 with free shipping from Indy Super bikes. The AT 200 is the generic version and is listed as the application for the VFR1200.
    Anybody already install one of these that can share your install experience and impression of the results? The VFR1200 has two O2 sensors, does it make any difference which one you replace with the wide band auto tune sensor?
  4. cornerexit
    I run it on my R1, and will on the VFR soon.
    On the R1 it works perfectly, fueling is absolutely perfect.
