Need new sprockets, should I go stock? vf500 86
Discussion in '1st & 2nd Generation 1983-1989' started by RoadRash2, May 21, 2013.
  1. RoadRash2
    RoadRash2 New Member
    Binghamton NY
    So, I should buy some new sprockets.. Anyone have luck veering away from the stock gearing? I would like to gear it up for more speed in hopes of not just gaining top end speed but also improving fuel mileage.. will it actually go faster? or will it just over work the bike? Thanks in advance. Jim
  2. RoadRash2
    Binghamton NY
    I bought a 42 rear(one tooth down from stock) a 15 and a 16 front. i'll let you guys know what the result is when i get it rolling around.
  3. slowbird
    slowbird Member
    Toronto, Ontario.
    I went 1 up on the front sprocket when I did my F2 wheel swap and it rubbed slightly on the Front Sprocket Cover.
    I'd stick with a Stock OE Front Sprocket from Honda as it usually comes with the Rubber on it. Get a new locking clip for the bolt while you're at it.
  4. lshark
    lshark New Member
    NY
    and be sure to use a torque wrench on those rear sprocket bolts !!!!!!!
  5. slowbird
    slowbird Member
    Toronto, Ontario.
    LOL! :tongue:
  6. RoadRash2
    Binghamton NY
    i'll just keep my eye on it, hows that? I have had enough things loosen up on me after i "fixed" them to keep me checking. Thanks though you guys :cool:
