need help... so as always..... one thing led to another
Discussion in 'General VFR Discussions' started by freeman338, Feb 25, 2010.
  1. freeman338
    freeman338 New Member
    Elkins, West Virginia
    so i bought my bike back in august. the person i bought it from had it since i was 17 and had been working on it here and there never really accomplished anything with it and i said if i ever got the chance to buy it i would so the chance just so happened to arise when my cash flow was plentiful so i said ok nows my chance so i bought it. oh and its wrecked by the way, so ive had it since august paid 500 bucks for it got a few pieces of the fairing, a vance and hines pipe and a half running bike but i didnt care because i love that bike. so now its february and im just now starting to really get in to rebuilding it bought all the fairings last week all 1037 dollars worth (ouch) so i start giving her a once over you know i got a few other things this week new carbs cause the ones on her are totally screwed someone tried to screw with them and totally messed their sync and mixture ratios beyond fixing with out rebuilding plus it hasnt been ridden in like 3 years so i figure eh ill rebuild them then low and behold found a bunch of stuff on ebay a few plastic pieces new carbs to make it much easier so i continue further into the guts of this machine and move on the front end you know pretty straight forward until i sit on top of my bike and notice the wheel is tilted to the side and my bars are straight!!!!....which begs the question is it my forks that are bent im pretty sure it is cause i can look at the forks from the side and they look like the one is kicked forward and one is kicked back i mean i dont have the straightest eye but my buddy was lookin also and i trust his judgement more than my own sometimes he said the same thing or he also thinks its my axle so if someone could help figure this out i would much appreciate it... by the way sorry for writing a freakin book to get to the point guys
  2. crustyrider
    crustyrider New Member
    North Country, New York
    if you take pictures from the windshield down..we might be able to see...but it sounds like your forks are bent replace both...not just one...hell put up some pictures anyway...
  3. safetypro10
    safetypro10 New Member
    Dallas, TX
    First, before assuming the forks are bent (unless you just want to go Frankenviffer), loosen the bolts on the triples, lower only, assuming the tops are equal and see if they go back in place. Also make sure the head bearings are tight, probably need to replace them anyway. Also check the axle bolts for tightness.
    After that you'll have to remove forks from triple and check them on the table for striaghtness.
    Larry
  4. 02 VFR Rider
    02 VFR Rider New Member
    sounds like they are twisted in the triple tree.
    loosen bolts, put front tire up against something and twist the bars untill the line back up w/ the tire.
    just like back in the day where you tweeked the front wheel on your bicycle.
  5. freeman338
    i was gonna try to get some pictures up here before to long cause right now i have it stripped down to the bare chassis and will probably check the forks tonight already got a new set on the way jsut in case though
  6. freeman338
    got my new carbs last week put them on this thing runs awesome it sounds really really good deep throaty sound, anybody have any experience with airtech fairings how hard are they to mount and what not never really messed with fairings before fiberglass yeah fairings not so sure guess ill cross that bridge when i get there...any help is much appreciated
  7. residentg
    residentg New Member
  8. reg71
    Sikeston, MO
    Agree with 02, try the cheap fix first... It's not that hard to get them crooked, but a lot of times you can straighten them back out without having to replace them. If you are really nervous, take them all the way out, with the front tire off, lay them down side by side and give them a good look. Get a good look at the triple (although it's hard to see if it's tweaked), re-install and see if it still seems twisted. If so, then start thinking about replacing... If I was going to replace, I might look to fleabay for a whole frontend, but then you still run the risk of buying someone's headache...
  9. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Hey Freeman, I know of a real good mechanic in Martinsburg (Joe Vital) who is a stand up guy.
    If he lives close you may want to contact him for some assistance.
    Let me know if you want his information.
    BZ
  10. freeman338
    well got the new forks today gonna take em' over to my buddies shop and have him rebuild them new seals, oil, oh and progressive rate springs woo hoo almost there put a new fan on the other day the hub on mine was stripped completely out now all i need are those darn fairings thats gonna be the nightmare im not lookin forward to i got a feeling its gonna be bad bad bad
