need advice for my 85 vf500f! please help!
Discussion in '1st & 2nd Generation 1983-1989' started by kjweisenbarger, Aug 10, 2010.
  1. kjweisenbarger
    kjweisenbarger New Member
    florida
    ive been having problems with my vf500f, ive cleaned the carbs countless times, replaced parts that needed replaced, i bypassed the vacuum in the petcock. still my bike wont pull past 5000 rpm. it feels like its not getting enough gas after 5 grand, it pulls strong from 1 to five thousand rpm. ive got good spark too. i am stumped on this bike. does anybody have any advice?
  2. invisible cities
    invisible cities New Member
    new york
    From the '84 Factory Shop Manual:
  3. slowbird
    slowbird Member
    Toronto, Ontario.
    CDI box? :confused:
  4. kjweisenbarger
    florida
    thanks alot! , this should help me. do u know where i can download the whole manual?
  5. Lazy in AZ
    Lazy in AZ New Member
    Mesa, Az
    I'll bet your cam timing is off a hair. We have a 'Busa 1300 sitting in the classroom that showed a horrible power curve on the DynoJet due to the intake cam sprocket having been spun from an engine seizure. The power was great until it hit high/mid range and then it dove and sputtered. If you held it wide open throttle long enough to get out of that power band it would rip open and go back to full power, but from 5500-8500 it was dead weight.
  6. tinkerinWstuff
    Not a bad thought Lazy. Especially considering known cam issues with the 500, it's very likely that someone could have removed a cam and got the timing wrong.
  7. ferrarone
    ferrarone New Member
    Manchester, NH
    I support Lazy's idea of cam timing. That's also a lot easier to check than pulling off those carbs and trying to put them back on again. If it is not a cam issue i would pull the carbs off and make sure compressed air can easily pass through all the passages. I use a rubber hose fitted with a basketball pump needle and blow with my mouth to check. Just a thought, first time I cleaned my carbs I never did that, and they were sparkling clean with the exception of a blocked connection. Good luck!
  8. kjweisenbarger
    florida
    thanks, i think that maybe my fuel pump might be bad because it ticks like crazy and is very inconsistent. could this cause poor performance?
  9. tinkerinWstuff
    some of the early pumps made a ticking sound with each stroke. They don't run constant. When the pump "dead heads" it will stop running. Meaning, when the carb bowls are full and the float shuts off the needle, the line pressure overpowers the pump and it cannot stroke any more. Once a little fuel is burned, the pump strokes again.
    So the question is why you think it's "inconsistent" and what symptoms of poor performance you have. My gut says you likely do not have a bad fuel pump but without more information it's hard to say.
  10. kjweisenbarger
    florida
    vf500f
    it appears that the bike has weak spark. i followed the procedure in the manual for checking the coils but it shows no continuity on the secondary side of the coil yet it still runs. how is this possible , am i missing something?
