My Vtec 2002 Dyno
Discussion in '6th Generation 2002-2013' started by mendeshgt, Apr 1, 2015.
  1. mendeshgt
    mendeshgt New Member
    Matosinhos, Portugal
    Hello this is my VFR Dyno test with the following tune mods:
    Data 5064 - Pair and flaper mod, Pipercross air filter, snorkel removal, Power Comander III with a map from dynojet site, Scorpion slip on exhaust.
    Data 5086 - all modifications above plus kat off and injection tuning in Dyno.
    I dont have the stock dyno, but it had around 100-101 HP.
    Does anyone know If I chose to change the PC III by a Rapid bike 3 would get better gains ?
    Thanks in advance and sorry my bad english.
  2. Lint
    Lint Member
    Simi Valley, Ca.
    So, you are saying that with those small changes, your torque was over 83 ft lbs and your HP was over 110? That is a 30 ft lb boost. That is very substantial. The HP boost is good to, but to boost torque that much seems crazy.
  3. mendeshgt
    Yes, the bike was excellent after removing the kat and with the fine setting of the injection on the dyno.
    On the road it shows enough improvement, especially among the 4 k and 7 k rpm, the bike was much stronger.
    However I read here that the rapid bike lets you tune the ignition, and wanted to know if buy these module (Rapid Bike 3) compensates to replace the PC 3.
