my vfr
Discussion in 'General VFR Discussions' started by pokerplayer6989, Mar 30, 2009.
  1. pokerplayer6989
    pokerplayer6989 New Member
    missouri
    hey guys to any one who has read me intro i got the bike in running condititon the motor smokes a bit but kinda expected that anyway got some stuck carbs and im looking for advice pls drop me a line
  2. Ghost_Rider
    Ghost_Rider Active Member
    LA & Utah
    Did this bike have old fuel sitting in it getting all gummed up and leaving residue?
    Assuming so, remove the carbs, disassemble them and let everything soak in carb cleaner at least over night. Make sure that the float bowls are clean, and floats are working and not sticking. You might have to use a small needle or the like to clean some of the clogged orifices of gummed up fuel residue. Replace the fuel filter. If you have not already, drain the tank of all old fuel, clean the tank, reassemble, with fresh fuel, and then run some fuel cleaner like Seafoam in it.
    If you do not have one, find/invest in a manual.
