move countershaft sprocket outboard - bc 5.5 inc rim
Discussion in '1st & 2nd Generation 1983-1989' started by Rune, Jul 31, 2015.
  1. Rune
    Rune New Member
    Norway
    Hi !
    Honda vfr 750f (year 86) with kawa. zx9 rear wheel 17x5.5.
    The countershaft sprocket has to be moved outboard. Is there a type adapter/spacer for this? Or a alternative sprocket with integrated spacer? Any suggestions?
    Br
    Rune
    Raeva mi verker !! Bigger isn't always better. :distrust: What are u using for f ront wheel ?
  3. NorcalBoy
    This is a common problem with supermoto bikes, just say I have had a little experience with this and it hasn't always been good. There are companies that machine offset sprockets to your specs, but once you start moving stuff around too much, >5 mm, it gets more in depth than just offsetting the sprocket. If you plan on running a 180 or 190 series tire, you are looking at a significant change in turn in ability and a loss of valuable HP.
