More on tires
Discussion in 'General VFR Discussions' started by reg71, Jun 29, 2006.
  1. reg71
    Sikeston, MO
    Okay, is the small rubber bridge in the tread kind of halfway to the outside the wear indicator? It seems like I have heard people say that. If so, are the tires ready to change when the rubber is worn down to them? I wonder because it looks like I'm gonna wear a flat spot in the middle from my commute to work before I wear down to it.
  2. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    I presume you mean the little "bar" that runs between the tread. Yes, that is the wear indicator. It very similar if not the same as on a car tire. When they start getting even with the tread, it's time to change tires.
