Modifications for track days
Discussion in 'General VFR Discussions' started by Louis290663, Aug 27, 2006.
  1. Louis290663
    Louis290663 New Member
    Hi,
    I'm looking for web sites where there are VFR 2002 and over that have been modified for track days.
    Louis
  2. RosscoB
    RosscoB New Member
    Austin, Texas
    It doesn't seem like the best dedicated track day bike with the abundance of F4 & F3's out there.
    I've had mine VFR at the track several times. It was fun and capable. It was not the perfect track machine. All I did was tape up glass, remove mirrors and change tires.
  3. flameface
    flameface New Member
    New England
    remove center and sidestand, remove mirrors, tape over the headlight and taillight, unplug headlights, tape over speedo, fresh brake pads in the front, readjust suspension at both ends, safety wire your drain plug, put a radiator clamp on your oil filter and safety wire it, drain the coolant and replace with distilled water. fresh rubber. scuff it in before you go fast
    if you get a front end wobble, retorque your steering stem bearings to the preload in the book.
    Buy a tire gage.
