Misc Accessory QA
Discussion in 'Gear & Accessories' started by Miles1962, Jun 22, 2015.
  1. Miles1962
    Miles1962 New Member
    Watsontown, PA
    Hi, already have a thread going regarding Powerlet connectors, here's another one:
    My 6th gen VFR has 20,000 miles, Honda hard bags, Heli-Bars, Sargent seat, Pilot rubber.
    Looking for recommendations/info for:
    Frame Sliders: i've seen various types but do not know which require cutting bodywork etc.
    Power Commander V: probably end up buying a used one off of a VFR for around $250. Is the "V" the only one for the 2002? Anything to watch out for? Wiring harness differences?
    Rear luggage rack: There seems to be slim pickings for the 2002, the few that i found look like bark busters, not accessories for a classy bike. Or too flimsy to hold a trunk.
    Rear trunk: big enough for 2 helmets (no bigger) with padded back rest.
    Air cleaner: K & N etc?
    GPS/Phone mounts: One that either uses the center cap of the triple clamp or the 2 bolt north of the tank. I've seen photos of both types and wonder what exists for modern phones such as the Kyocera-Verizon Brigadier phone. What is a "Ram" mount?
    Voltage Regulator: what brands/suppliers are the best?
    I apologize for the broad range of threads my questions range over, i will be using comments here to supplement poring over existing threads at the same time. The main reason i am going ahead with this multi-pronged approach is to get current info on issues, strange that a 2002-2013 bike is getting harder to outfit.
  2. mofo
    mofo New Member
    Orange County Ca.
    First off, for my opinion on frame sliders please read my signature.
    For luggage rack and trunk, I have the OEM rack and trunk. It holds two full-face helmets or if need be, at least 50 12oz. cans of beer. I don't recommend you carry those 50 cans due to the weight limit per the manufacturer though.
    I use OEM air cleaner and it works just fine for me.
    GPS, what's a GPS? I've never used one and have found great roads and interesting places by getting lost. Running out gas may add to the experience.
    I don't use a power commander and have not had any issues with the OEM voltage regualtor.
  3. Grumpy old man
    Grumpy old man New Member
    New Zealand
    Cambridge, New Zealand
    Google search took4 seconds to find these "Ram mounts"
    https://www.rammount.com/products/motorcycle#/
    As for frame sliders anything faster than a tip over at walking pace will usually result in the mounting point for the slider being damaged and as a lot of them use use expensive engine to frame bolts etc I personally will not ever fit them
    I have a PC 3 usb on my 2004 6th Gen with "Cozeys" map works just fine
    Get a decent Gps if you need one then you will only need to mount it with a single ram mount and your phone can stay in your pocket and be controlled via the GPS via bluetooth (less clutter around the bike this way)
    I have a Givi FZ166 mono rack with a V47 top case and I can get 2 full face helmets in it
    Factory OEM air filter for the win
    Stock reg/rec seems to be holding up so far at 55,000kms Just install a voltmeter to keep an eye on what is happening
    And maybe spend a rainy day in the shed inspecting and cleaning the wiring loom and connectors
  4. Miles1962
    Watsontown, PA
    Thanks Grumpy, I'll probably pass on the sliders until i hear of a better mounting design. I'm going to use my Kyocera Brigadier phone for GPS, just need to find a mount that works with it and mounts to the bike well. Is the Givi case rated for volume? I noticed some are given in liters.
