Manual tensioners
Discussion in '6th Generation 2002-2013' started by Lint, Aug 20, 2015.
  1. Lint
    Lint Member
    Simi Valley, Ca.
    I'm going to go this route. Will this work or do I need some "name brand? "
  2. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    You would rather adjust the cam chain tensioners every couple thousand miles, than replace them every 30,000 miles or so?
    My CCT's have gotten loud at 30,000 and 60,000 miles, but I have heard of people making it to 80,000...
  3. Lint
    Lint Member
    Simi Valley, Ca.
    Most reviews by people that have them only touch them once every 10k miles. Even if I do adjust them every 10k, at least I don't have to keep buying new.
  4. stoshmonster
    stoshmonster New Member
    I went with American Performance Engineering (APE) manual cam chain tensioners on my '03.
    Takes a bit of time to do it Lint but they're actually pretty simple to install and adjust.
    The rear cylinder chain tensioner is easy enough to access but the front is a bit more complicated.
    Coupla things under the fuel tank have to be moved out of your way to get in at it but it's doable.
  5. Lint
    Lint Member
    Simi Valley, Ca.
    Thanks, Good to know.
  6. Lint
    Lint Member
    Simi Valley, Ca.
    Do I just leave the cap off of the tensioner, as there is no way to attach it?
  7. Lint
    Lint Member
    Simi Valley, Ca.
    Never mind...
