Main Relay on 83 vf750f
Discussion in '1st & 2nd Generation 1983-1989' started by rob24, Aug 9, 2014.
  1. rob24
    rob24 New Member
    I believe I have a bad main relay...I am getting volts to the main relay "red wire" but I feel its not closing when I turn the switch on so the "bl/bu wire can feed volts to my fans..To take it 1 step further,I have no volts at the 10a fuse which feeds the 2 couplers to my fans..
    I know the fans works cause I straight wired tested them both...I also used the original shop manual to trace wires..
    My 1st question is can I not put a jumper wire between the red and the bl\bu wire so I would have voltage to run fans??
    Q2 Where can I buy a replacement, since this relay is obsolete..It is 4 pronged square open relay at 22amps..
    Sorry for not explaining my problem in detail the 1st 2 times..
    Robert
  2. NormK
    NormK New Member
    I.m not sure what you have but have you checked the relay, does it work, if not just get another relay it is only an electrically operated switch, nothing mysterious about them
  3. Allyance
    Allyance Member
    Germany
    East Bay, California
    Honda used a relay because they didn't want to switch heavy load through thermostatic switch. Wouldn't recommend trying to bypass relay.
  4. rob24
    rob24 New Member
    OK people,I am looking for solutions to my main relay problem or a place to buy a main relay for my 83 VF750F..Thanks..
  5. NormK
    NormK New Member
    Ok how many pins on the relay,4 or 5 I'm just guessing but this is what I would do, go to auto parts shop and get a 30 amp relay probably cost you $10 or get one from China for probably $3
