Main fuse blows at attempted start
Discussion in 'Mechanics Garage' started by jdmbird83, Apr 17, 2024.
  1. jdmbird83
    jdmbird83 New Member
    Columbus, OH
    Hey all, I've got a 1994 VFR that during a short day trip a few years back, suddenly died. I had already purchased a VFRNess and new regulator, so I went ahead and installed them. I found that the Main fuse had blown as well. I replaced the main fuse, and every time that I would go to try to start the bike, it would blow again. I swapped back to the original regulator, and there was no change. I let it sit for another year, and was able to get the starter to turn over for about 10 seconds this time, before again blowing the main fuse. I went through all of the wiring on the vfrness and ensured that all connections were good, however I am now at a loss as to what could be causing this fuse to blow. 99% of the time, it will blow at the press of the starter button. I should also note that the battery has been changed out for a fresh one as well.
    How many miles on the bike and the general condition?
    First things I would verify:
    Condition of the plug and wires at the starter solenoid near the main fuse. Known problem area on VF/VFRs.
    Condition of the starter and ground cables and their attachment points. Perhaps very high resistance from corrosion.
    Starter motor itself. Is it full of armature brush dust? When it does turn over, does it do so with any speed, or is it sluggish?
    Inside of the Starter Switch Assy on the right bar. Clean and corrosion free?
    I'm sure others will have more, perhaps better, things to check and try. But those would be the first things I verified.
    Thumbs likes this.
  3. Totaled TL
    Totaled TL New Member
    Louisville, KY
    Consider replacing the starter solenoid. Maybe there is high resistance across the high current contacts.
    Captain 80s likes this.
  4. Grum
    Grum New Member
    This reply is a copy and paste from my reply of the same query posted on VFRD.
    Just to be clear....
    1 - Was a blown Main Fuse 30amp in the Starter Relay the cause of the bike dying on your short day trip? OR has the fuse issue Only happened since the wiring change?
    2 - And with the R/R unplugged. It still blows the fuse Only when pressing the Starter button?
    3 - Your are absolutely sure, this fuse Only blows when pressing the Starter button, and Not just with turning the Ignition Switch to On?
    4 - Assume the replacement fuse is a 30amp Fuse? Sorry, but need to be sure!
    5 - Do you have photos or wiring diagram of the changes you've made?
    My gut feeling at this stage is there's something strange going on within the Starter Relay when being energised. Independent checks on the Relay can be run after hearing back regards questions above.
    squirrelman likes this.
