Lower airbox/plenum 86 vf500
Discussion in '1st & 2nd Generation 1983-1989' started by jstehman, Nov 13, 2020.
  1. jstehman
    jstehman New Member
    Picked up an 86 vf500, come to find out the lower air box plenum is broken in places
    Might be repairable with a lot of custom jb weld and sanding, but I figured I should try eBay to see what's out there.
    I found a plenum from an 84.. part numbers are different.. how much of a difference is there between 84 and 86 vf500? Will the part interchange?
    Edit:
    The air cleaner base on this carb set does not have the holes for the carb vent cossover tubes.. yet the carbs have the tubes that look as if they should fit into a base that has holes in it.. like the 84 base. There's a sticker on the air cleaner lid that lists the air cleaner base from an 85, so there must be some difference.. hoping it's the holes for the vents. Just like the 82/83 vf750c magna has the same.?
    Maybe I have 84 carbs and an 86 base?
    Sent from my SM-N950U using Tapatalk
  2. raYzerman
    raYzerman Member
    Millgrove, ON
    Permatex Plastic Epoxy is very good stuff, better than JB.
  3. straycat
    looks like someone levered on the plenum to get the carbs out at some point.
    Ebay is a good bet for a new one
  4. jstehman
    jstehman New Member
    I've found an air cleaner base for an 84, are they interchangeable?
  5. straycat
    I dont know the answer to that one, someone here will chime in soon with the correct answer, Im sure of that
  6. jstehman
    jstehman New Member
    It looks like the main difference is the holes for the carb bowl vent tube to go into the base.
    Carb bodies are Most Likely the same. Netting and needle sizes may be different for year to year I'm sure.
    Not familiar with this model yet. If it was a Magna, I would already know
  7. shields17
    shields17 New Member
    Italy
    I don't think you can interchange parts between the 84 and 86 carbs sadly. The '84 are 32mm and the '86 are 30mm. I've just been out to have a look as I have '84 carbs on the bike and a set of '86 in pieces... It's difficult to get anything into the plenum to measure the exact difference but the picture below shows the size difference in the washer for each set, the '84 is a good bit bigger so I don't think you'd be able to mix and match.
    Correct. I've got 2 sets of carbs on my bench right now. 84-85 will not play with 86.
  9. jstehman
    jstehman New Member
    Let me see exactly what carbs are in there because the lid looks like it was bought in eBay and says for 1985
    [​IMG][​IMG]
  10. jstehman
    jstehman New Member
    Are these the correct carbs for 1986 vf500f?
    That's the engine serial number, and I have the line bored heads.
    Feel like I'm kinda screwed right now
  11. shields17
    Italy
    VD56 are the 84-85 32mm carbs
  12. jstehman
    jstehman New Member
    Just got the carbs out today.
    Sooooo this isn't gonna work huh?
    You can run the 32mm carbs on the 86 Engine. That's what my Race VF500 had. And the 84-85 Insulator Boots are cheaper then the 86 items.
    So if you can get a 85 plenum (like your cracked one) for a reasonable price, you might be in business.
    jstehman likes this.
  14. jstehman
    jstehman New Member
    I hope you are serious, because that is the best news I've heard all day!!
    I'd send you a drink if I could. If you're into that kind of thing . Otherwise, man you toally made my day. THANK YOU
    I am waiting for my drink...
  16. jstehman
    jstehman New Member
    This one or this one [​IMG]
    Think I'll go with the first one to go with my Bulleit back.
    Fine... I'll grab my own.
  19. jstehman
    jstehman New Member
    Looks tasty!
    Pulled the trigger on that 84 lower plenum. Hopefully that will get me closer to running.
    Then it's on to valve clearance, compression check, hydraulic rebuilds etc. Maybe start a resurrection thread
  20. Waylander
    Waylander New Member
    Waltham Abbey, Essex, UK
    You should have a go at plastic welding,
    Old soldering iron and a lot of patience and some ABS welding sticks off eBay
    I have fixed loads of plastic on my FII even completely remade some parts
    VF1000F2F, in bits
