low to high beam "delay"
Discussion in '7th Generation 2010-Present' started by lshark, Nov 5, 2012.
  1. lshark
    lshark New Member
    NY
    my 2010 just started recently to take some time to switch from low beam to high beam after i throw the switch first time it took maybe ten seconds then less until it returned to normal...anyone exp this or have any thoughts ??? it happened the last couple of times i rode at night...all stock...i use high beam at all times in daylight..... thnx
  2. 34468 Randy
    Can you say that this happens all the time? Have you owned this since new? Personally, I wished mine did this because I have HID lights all around. If I have my High Beams on at the same time as the lows, I blow fuses. The power being drained during the warm up stage is to great for the fuse. If I let the lows warm up first, then switch to highs, I am OK. What I am saying here is, if someone else owned this bike before you, he may have had a delay relay in there for this very reason. This will be one of my mods for this winter.
    BTW. :thumb: on the high beams during the daylight hours. But they are far to bright for night time use if there is traffic around. I do the same thing. Technically illegal most places but fugm
  3. karazy
    karazy New Member
    Halifax, Nova Scotia, Canada
    My first guess would be a slow relay. There should be one for lows and another for highs. They are usually identical and can be swapped, but verify that there is no delay with the lows before doing this.
    :crazy:
  4. lshark
    lshark New Member
    NY
    it is stock i bought it new(17K miles ) ...happened first time a few weeks ago again the other night...silly hurricane kept her in the garage in between....wasnt sure if there were relays or what..going to the dealer but i appreiciate the info thnx
  5. lshark
    lshark New Member
    NY
    i like to be able to tell them what's wrong wth the bike instead of asking
  6. lshark
    lshark New Member
    NY
    fugm is right safety first !!! i also got into the habit from the old days of sealed beam hi/lo in order to put the majority of hours on hi beam so not to be stranded at night with burned out
    lo beam
    BTW. :thumb: on the high beams during the daylight hours. But they are far to bright for night time use if there is traffic around. I do the same thing. Technically illegal most places but fugm[/QUOTE]
  7. RoughneckRed
    RoughneckRed New Member
    This exact thing happened to me for the first time about a week ago. Bike is a 2010 completely stock. Thought it was was the switch at the time because it seemed to work after repeated attempts. Please let us know what the dealer says about the problem.
  8. lshark
    lshark New Member
    NY
    won't be till next week, just got power back on, another storm on the way and it's cold...better weather next week....do you have ext warranty??
  9. RoughneckRed
    No picked it up august of last year so I'm just out of warranty.
