low beam bulb recomendation?
Discussion in '6th Generation 2002-2013' started by mtg125, Nov 9, 2013.
  1. mtg125
    mtg125 New Member
    St Louis, MO
    Lost both my low beams, one two days ago, and one yesterday. Looking for a reasonable replacement. I don't do much night riding so don't want to do anything to costly. I run the piaa intense white on my mean streak and it has been great for years, is this a suitable bulb for the vfr? The specs look the same, just wondering if anyone is running them.
  2. Scubalong
    Silverstar Ultra Bright is your solution if you not going for HID :thumb:
  3. safetypro10
    safetypro10 New Member
    Dallas, TX
    What he said. You will need a H4 to H7 conversion disk, or make your own.
    Best investment I ever made. White, bright, and last long. next would be HID.
    Larry
  4. judobrian
    judobrian New Member
    Colorado
    How much did it run you? Tough to do yourself?
    Thx
  5. Scubalong
    You just need to snip the two taps on the side and leave the top tap to align with the slot...............Voila done :thumb:
  6. safetypro10
    Dallas, TX
    Nope, easy.
    A. Keep fingers off bulb at all times.
    B. Remove front fairing.
    C. Remove screw holding bulb retainer down.
    D. Remove retainer, remove bulb.
    E. Put Silverstars in H4 to H7 adapter.
    F. Insert into bulb socket.
    G. Tighten down retainer with screw.
    H. Replace front fairing.
    See? Easy.
    Or you can skip the fairing removal if you can get your hands up in there to reach screw under weather seal.
    Larry
