Louisville, Ky Good Mechanic ?
Discussion in 'USA - South' started by robwoo502, Jun 2, 2016.
  1. robwoo502
    robwoo502 New Member
    Louisville, Ky
    I just picked up a Red 98 Honda VFR from a previous member kentuckythunder about a month ago. I'm located in Louisville and I'm looking for a mechanic in the area that is solid, reasonable priced, trustworthy, and knows his way around Hondas. I do have maintenance records, but I don't think the Valves have ever been checked adjusted on this bike. I'm right at 22,000 miles. If anyone has a recommendation for a good shop /person in the area please let me know ?
    Thanks In Advance
  2. danman313
    danman313 New Member
    I have a 95 vfr 750f.. and having problems finding the needle bearing 4 the hub.. they discontinued that 1 hub u could buy had bearing in it. Not sure if I have factory hub or other 1. This hub only says e 1 on it nothing else.. any had this problem just got bike painted ready ride no bearing 3 Months looking 4 the rite needle bearing. Any help plz. Thanks
    Sent from my SAMSUNG-SM-N900A using Tapatalk
  3. NormK
    NormK New Member
    What country are you in, I don't believe you can't get a bearing for it. Does the bearing have a number on it?
  4. danman313
    I'm in the usa. And it my b my guy have looking but ordered 4 and was 2 big 4 95 vfr 750 f..
  5. danman313
    And bearing was destroyed nothing left of needle bearing. Dust. So no numbers just the E1 on the hub adjuster bearing holder
  6. danman313
    I live in portsmouth ohio
  7. NormK
    NormK New Member
    Take the hub and the spindle to a bearing shop and they will be able to measure it up and tell you what is available for it
  8. danman313
    He said his other shop mechanic had same problem 1 time. Have a bearing on way suppose fit. Just try c if able have 1 made if not..
  9. NormK
    NormK New Member
    Sounds like somebody is dicking with you if you have been waiting 3 months for a bearing
  10. danman313
    Yeah there r 4 different models 4 rc 36. I'll figure it out it says 94 -97 fits. Suppose 2. About just go Honda with my hub and make sure get rite 1. This guy has gotten bearings but could've ordered wrong. Plus I don't like any touching my bike. Lol. Safe riding !!!!!
  11. danman313
    Got right bearing finally 4 my rear hub. 3 months. But had painted. Finally back on road. And found out had 2000 so ething vfr spark plugs in it. 2 threads longer than 1's suppose 2 b in it.. got lucky..
