Lost Horn, Indicators and Brake Light
Discussion in '5th Generation 1998-2001' started by Roccoaster, May 23, 2017.
  1. Roccoaster
    Roccoaster New Member
    France
    Germany
    Hi Gang
    It's been a while since I was last here so I just wanted to share an experience I've had today when I lost indicators, horn and brake light function. Read up earlier today a few threads including one on here which helped motivate me to have a crack at it. The associated 10A fuse had blown and blew the spare one just by turning the ignition on.
    Removed all the fairing and had a look for obvious signs of wiring damage - none. I have the VFRness fitted after suffering a few knackered rectifiers so wondered if that might have come unstuck. Everything looked fine so I disconnected the horn wires, indicators front and back were already off and since the turn signal relay was the most likely cuplrit, pulled the connector off of it. Reconnected everything except the TSR and the 10A fuse didn't blow.
    So, this Mitsuba FR-3303 needs to be replaced and costs about fifty quid but I do have one question. What is this connector for? It's located above the seat release catch and under the fairing/cowling. Any ideas?
  2. RllwJoe
    RllwJoe Insider
    That, I believe is the jumper connection for accessing the trouble shooting codes from the ECM.
  3. RVFR
    just a what it's worth part, check your front brake light switch under the the master, those little connectors can touch each other, and or double check the horn wiring too. don't ask how I know. .
  4. OOTV
    OOTV Member
    RFVR beat me to it. The front brake switch can sometimes short out when the wires are too close to the clip-on or if the wires got tweaked a little. This happened on both my VFRs and on the 6 Gen you lose the entire dash and headlights...You can ask me how I know!
  5. Roccoaster
    France
    Germany
    Cheers fellas. I did notice one of the spade connectors on the front brake switch was bent when I pulled them off for testing. I'll check again tonight.
    As soon as the new 10a mini fuses arrive, I'm going to connect the original relay again and be 100% sure it's that which is faulty. If the fuses blows then I'll know.
    Not bought the new Mitsuba relay yet, and am considering a much cheaper version >>> http://www.ebay.de/itm/lastunabhaengiges-LED-Blinkrelais-Relais-elektronisch-Honda-wie-Mitsuba-FR-3303-/130802136456
    Anyone else bought one? The size and shape is completely different but if it works...I'll save myself about €50.
    Cheers
  6. Roccoaster
    France
    Germany
    Stuck the turn signal relay back in tonight and fuse didn't blow! So I can only guess that pulling connectors off and back on again has some how solved the problem. Haven't put the headlight and front indicators on yet so we'll see if the good news lasts until tomorrow. Ho-hum. :)
