loss of power
Discussion in 'Mechanics Garage' started by California Dreamin, Aug 27, 2011.
  1. California Dreamin
    California Dreamin New Member
    Stockton Ca
    1987 vfr 700 i have owned for 6 months. I switched to premium gas a month ago, 2 weeks later it started feeling like it was out of gas, but it wasnt. I can only ride for 20 minutes or so and then it acts if its out of gas agaim. If i let it sit for a few hours it will start right up. I put lucas fuel cleaner in put i think it ran long enough to work. Any idea's?
  2. bobthebiker
    bobthebiker New Member
    those fuel cleaners in a bottle, unless they're B12 chemtool, do nothing, zero, zip.
    it sounds like your issue may be that you need to pull and CLEAN the carbs. no bottle of cleaner will do that. none.
  3. TOE CUTTER
    It does sound like a fuel issue, I am thinking you need to verify that the fuel pump is operating correctly when at temperature. Run it until it fails and jump the blue/black wire to battery to see if it is still operating, they are prone to failure given the age of the beast. There is a relay that operates the pump and it gets a signal from the pick up coil to fire the pump and you need to verify that the pump has stopped pumping and that it is not an issue with the wiring or the relay. When you jump the blue/black wire to battery positive it should run until the bowls are filled and if it does not the pump has most likely taken a dive.
  4. TOE CUTTER
    Where in California are you?
  5. California Dreamin
    Stockton Ca
    Stockton, originaly from The City
  6. TOE CUTTER
    I am in Sacramento, your close enough that if you need a hand we can work this oot over a beer or two. I am off work for the next 6 weeks so my schedule is wide f'n open.
  7. California Dreamin
    Stockton Ca
    wow thanks i might have to take u up on that offer
  8. Spike
    Spike New Member
    I would think something like a pinched vent tube or something like that may be the place to start, did you recently do any sort of work ont he bike?
  9. California Dreamin
    Stockton Ca
    I had to reconnect the rectifier wires...thats it
