losing the decals!
Discussion in 'General VFR Discussions' started by sparky750, Dec 25, 2009.
  1. sparky750
    sparky750 New Member
    sylva, nc
    hey gang, merry christmas to all. ok,...is there an easy way to remove the vfr decals without scratching the plastic or losing my fingernails?:confused: i picked at one for several minutes and made absolutely no head-way :mad:. incidentally, i have a 2000 yellow (the fastest ones, btw!). is there a chance i'll see discolouration (the bike seems to have been garage kept, but i've only had it since mid october). thanks!
  2. jay956
    jay956 New Member
    Richmond, Virginia, United States
    heat gun/hair dryer
  3. sparky750
    sylva, nc
    Thanks!:thumbsup:
  4. Badbilly
    Better the hair dryer than a heat gun IMO. Heat guns can blister paint and melt ABS if not used very carefully.
    Any adhesive residue can be removed with plain paint thinner. This will also remove any wax on the paint. Other mild solvents that will not harm the clearcoat are Stoddard Solvent and VM&P naptha.
  5. sparky750
    sylva, nc
    great point about the heat gun! thanks
  6. jay956
    jay956 New Member
    i figured it went without saying that high heat and plastic didnt mix, lol. but your right, there probably is someone out there that would use a heat gun on high on plastic.
  7. Badbilly
    Or a propane or cutting torch. ;)
  8. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    In addition to a hair dryer you'll also need a six pack of ice cold pale ale. :wink:
    Regards,
    Rollin
  9. kd4ysi
    kd4ysi New Member
    Columbia, South Carolina, United States
    anthoer thing to use on the left over glue is googone it works great ,whats up rollin
