looking for ultrasonic carb cleaning
Discussion in 'Mechanics Garage' started by donald branscom, Jul 21, 2010.
  1. donald branscom
    donald branscom New Member
    Guerneville CA
    Do any forum members have ultrasonic cleaning equipment, or know where that service is available.?
    I need the stripped down carb bodies ultrasound cleaned.
  2. Rangerscott
    Rangerscott New Member
    Texas
    Google pine sol cleaning.
  3. donald branscom
    Guerneville CA
    Very funny. Ha Ha Ha
  4. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    I don't know what these people use, but back when I was wrenching on boats, they performed minor miracles. I took in a few carbs that I though were history, and they did an excellent job of restoring them;
    Carburetors: Recarbco - rebuilt carbs and throttle bodies
    They're in Pittsburg, CA.
  5. donald branscom
    Guerneville CA
    They do great work, but I can do them myself, and I do not have that kind of money to spend.
    But thanks for the suggestion.
  6. Rangerscott
    Texas
  7. vfr2k2
    vfr2k2 New Member
    Ontario, Canada
    Check out Harbor Freight..
  8. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    The pine-sol cleaning looks good. But 1-3 day soak is a tad much. I've been using straight Simple Green. It will clean just as good or better in only a couple of hours. Stuff is better than the acid type carb cleaner.
  9. donald branscom
    Guerneville CA
  10. donald branscom
    Guerneville CA
    I have a gallon of Simple green too and I will try.
    I think soda blasting or ultrasonic cleaning may be the only option.
  11. Rangerscott
    Texas
    The problem simple green is it takes the oil out o rubber. So make sure all vac lines/boots/etc are off.
  12. Lgn001
    Lgn001 Member
    What I was thinking, with regard to Recarbco, is that they might be willing just to soak/clean the bodies for you. You're right; they are expensive. They were expensive 20 years ago, too, which is why I only took them customer's carburetors that I knew were going to be tough to find replacements for.
    If nothing else, they might tell you what they use if you sound like a potential customer.
