looking for thoughts on pegs
Discussion in '6th Generation 2002-2013' started by zoomy, Nov 7, 2008.
  1. zoomy
    zoomy New Member
    Atlanta
    Wondering if anyone can give me a good reason to keep the footpegs on. In my recent trips to the twisties (Deals Gap) I've found myself scraping them quite excessivly, which frankly scares the hell outa me every time it happens. I've got my first track day the day after tomorrow and removed them in preperation. Any reason to put'em back on?
  2. drewl
    drewl Insider
    Virginia Beach, Va
    You need a place to put your feet.
  3. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    What drewl ^^ said.
    Where were you planning on putting your feet during track day, out of curiosity?
  4. NorcalBoy
    I think he's talkin' about the "Hero Bolts" on the end of the footpegs.....:tongue:
  5. zoomy
    zoomy New Member
    Atlanta
    Thanks for the correction NorcalBoy. "Hero bolts are what I'm wondering about
  6. drewl
    drewl Insider
    Virginia Beach, Va
    Go ahead and take the peg feelers off. I have seen several that were ground down anyway.
  7. Lgn001
    Lgn001 Member
    Doh! NOW I get it... Thanks! I thought maybe zoomy had some seriously small and flexible feet.
    Sorry 'bout that, zoomy!
  8. KC-10 FE
    KC-10 FE New Member
    If you are consistently grinding your pegs in turns, start working on body position. Body position can take the place of lean angle & is quite effective. Obviously, I can't tell you how to do this over the internet, but take a look at the guys on racetracks. If any of them are completely upright on a bike, they should be very easy to pick out. They will be in last place.
    KC-10 FE out...
    :plane: :usa2:
  9. DAN-SLO
    DAN-SLO New Member
    Agree witk KC-10 FE,if you ride with knee down take them out but every day comute leave them in because you have good indication on bike angle...
  10. Spike
    Spike New Member
    the hero pegs are meant to be the first to touch down, so that you have a warning, removing them means you are that much closer to something harder touching down, and you might like that less, not that the pegs are made to be able to pivot up, for the very reason of when the touch down, you don't "lever" the tires off the pavement
    If this is a constant problem, you might want to look at your rear shock and changing your settings, or an aftermarket one with adjustable length.
    Or body position as previously mentioned.
    or look at a set of aftermarket rear sets, usually they offer some adjustment, so you could mount your pegs higher.
  11. emptyskull
    emptyskull New Member
    near the bat cave
    get aftermarket rearsets raise them up about a foot or so you'll be fine...
