Looking for a complete 84vf750f exh system
Discussion in 'General VFR Discussions' started by Gregg in ohio, Sep 17, 2012.
  1. Gregg in ohio
    Gregg in ohio New Member
    kenton ohio
    got this 84vf750f and its got this aftermarket exh system on it might be a D&D short little mufflers all ceramic coated..want to ditch it and go stock...sure is alot of tubing under the engine 2 muffler system.still uses center stand..gonna have to rejet the system or change out the exh id rather have quiet...gonna be a tedious task...but if anyone sees one anywhere .....or will a 83 750 system work??? pretty nice bike wanna fix it up stock..gregg
  2. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    You probably just need mufflers as it sounds like you have a slip-on set on your bike now. Stock mufflers are hard to find (any exhaust parts are difficult actually) but posting up a WTB/WTT might net what you are looking for. Good luck!
  3. Gregg in ohio
    kenton ohio
    no its a denfinite aftermarket complete system...no exh collector all seperate pipes going 2 into one on each side. all pipes are equal length..all the header pipes are ceramic coated black..not a stock system..no rust on these pipes..gregg
  4. Vfryellow
    Vfryellow New Member
    Indianapolis, Indiana, United States
    Look in this thread. Leave a part take a part.
  5. Gregg in ohio
    kenton ohio
    hey jamie...i found a 84 vfr750f stock shock that actually works..when it fails ill get a modified one from you,,gregg wills
  6. Gregg in ohio
    kenton ohio
    im gonna try and see if a stock muffler will fit the exh pipes,,,its running so lean now..hi flo air filter and carbs were not rejetted for the aftermarket system...and some small parts for a nice stock restoration over the winter..i remember having one when they were about 2 yrs old back in the day..this makes 4 interceptors in the corral...and i did pick up a real nice unmolested stone stock 21k mi 92 honda cbr600f2 to thrash and save the interceptors from abuse..its alot easier to manuever in trafic and move around in the shop...and totally friggen fast...havent had a speeding ticket since 1968 i can feel one comming with the cbr..gregg in ohio
