Linked or not???
Discussion in '6th Generation 2002-2013' started by czakky, Dec 15, 2012.
  1. czakky
    czakky New Member
    So while cleaning and lubing my chain today i noticed a little bit of brake drag on the rear...no big deal, but as I hit the front lever (as wheel is still free spinning) nothing happened the rear lever works fine.... What gives??
    P.S. do not buy cheap ass Volar chains 4k miles and its toast even with regular maintenance...
  2. tinkerinWstuff
    there is a piston mounted on your front left caliper. when you activate your front brake, torsion on the caliper activates the piston and pushes fluid to the rear caliper. Thus, rear braking is always proportional to the amount of front stopping power and not lever input.
    duelly noted on the chain
  3. Durk
    Durk New Member
    Pittsburgh, PA
    I did some thread whoring when I saw one on ebay for $45.
    You aren't kidding, some people sounded like they were lucky to be alive.
  4. zoom-zoom
    zoom-zoom Member
    BC, Canada
    At the risk of sounding stupid, does the rear brake work the same way? From the service manual it shows a diagram depicting the rear brake lever actuating the middle pot on the front caliper. Does the rear caliper also modulate the braking pressure in a way similar to that of the front caliper?
  5. stoshmonster
    stoshmonster New Member
    Here's an edited old post of mine which explains the operation of the 5th and 6th gen. Linked Braking Systems for you Zoom-Zoom. Hopefully this should give you a better understanding of exactly how the LBS system works.
  6. zoom-zoom
    zoom-zoom Member
    BC, Canada
    Thanks for that Stosh. Your explanation goes a long way to helping understand mentally that which I can feel while riding.
