Hi all, This is my first post so work with me. I was on the track a few days ago and crash landed doing 80 in a hair pin turn (I know i know) and now my indicator lights arnt't functioning. My running lights work fine. Head lights, taill lights and my side lights. But, when i indicate the lights turn off and wont indicate. This goes for my break light too, works, and soon as i break nothing happens. Someone help me out please. My bikes a 1999 VFR.
Blown fuse? I haven't looked at a wiring diagram to see if they are on a different circuit for some reason. Generally they are not but it's worth a look. Otherwise I'd go with a stuck switch or start looking for loose wires (i.e. one that's been cut). -Jake
It very well could be a fuse. The brake light and signals are on a different circuit than the running lights and headlight. I know this for a fact since I recently had a fuse issue that caused the opposite problem, i.e. turn signals and brake light worked, but no headlight, dash or running lights. The fuse box is under the seat on the right sub frame rail.
