Has anyone noticed that after fitting Genmar bar risers to a 2000 vfr, that the front end is very light and the bike is now dicey when overtaking artic lorries, as mine is and I am not sure if it is because I am sitting slightly futher back and more upright therfore catching more wind and being blown about alot more especialy on motorways, in fact it is quite frightning.
You can adjust your suspension settings to make the bike slightly more "neutral", that should put a bit more weight back on the front for you and make it more stable at the same time.
I think he is saying that when he is passing large trucks now, the bike is pushing him around more now then before the mod.
Thanks, i had my rear suspension set at no 2 as that is what the book says is a normal setting but I realize I weight about 16 stones with all my gear on, I will try putting it up to no 4 which should raise the rear and put more weight on the front wheel which should make me more stable.
