LED Integrated Mirrors
Discussion in '5th Generation 1998-2001' started by nvoges, Feb 4, 2009.
  1. nvoges
    nvoges New Member
    Columbus, OH
    I've seen a few LED integrated mirrors on the 5th Gen's, but I'm unable to find a suplier. Have any of you purchased a good set?? What models will fit a 98?? Any help would be appreciated.
    While I'm at it, where's the best place to get mirror extenders?
    Thx,
    Nic
  2. drewl
    drewl Insider
    Virginia Beach, Va
    There is a guy on VFRD, lobster something or other, sells extenders called 'lobstenders.'
  3. CdnVffer
    CdnVffer New Member
    Ottawa, Canada
    There is a video on "youtube" showing a guy with them on his bike, I don't know though if it's still on there though! Also as for the extenders and intergrated led's you can find them both on Ebay under VFR.
  4. Joe Foe from Buffalo
    Joe Foe from Buffalo New Member
  5. soundmaster31
    soundmaster31 New Member
    Jackson, Michigan
    check my gallery(LINK) for comparison photos.
    They work great, but the LED's aren't the brightest in the world during the day and the brackets are an abs plastic type...only complaints. I did need to buy some bolts at Home Depot or Lowes too... some kind of Hex-cap bolt in black. The set came with a nut and bolt...i wanted a simple screw in application and plus, the regular bolts couldn't be turned from the top due to the bracket design, but a certain hex-cap size does and they were <$3.
    Ebay links:
    Carbon
    Black
    Chrome
    Search "Integrated Mirror" and you'll find a bunch of other styles that are more OEM shapes and what not.
  6. soundmaster31
    Jackson, Michigan
  7. nvoges
    nvoges New Member
    Columbus, OH
    What kind of relay do I need? Would a resistor do the trick?
  8. hondajt
    hondajt New Member
    springboro, oh 45066
    yes, a resistor would do the trick, but it would have to be stragecially placed. A Relay made for LED's turns is the best idea though.
  9. soundmaster31
    Jackson, Michigan
    it depends on what resistance you're getting from your current setup compared to stock(as long as it's the stock relay). I don't know the numbers off the top of my head. But there are lot of places that sell relays made specifically for LED systems which would be the easiest fix. Otherwise you're looking at soldering resistors in for every LED connection. You can get resistors for whatever your need at radioshack or online.
    Where'd did you buy your LED signals at? They might have the relay available through them. When I added my LED mirrors on to my stock blinkers I didn't have to change the relay at all.
  10. nvoges
    nvoges New Member
    Columbus, OH
    I ordered them off of E-bay from a company callled Fly-N-Cycle Motorsports eBay Motors: INTEGRATED MIRRORS CBR600 F4 F4I CBR900 CBR954RR (item 220349576097 end time Feb-05-09 03:38:12 PST). I may be able to check the resistance of the existing bulbs and make a determination from there. I'll let you know how it works out.
    Thanks,
    Nic
  11. leftcoast
    leftcoast New Member
    somewhere near Seattle, but my heart is just north
  12. Joe Foe from Buffalo
    Honestly I don't know for sure. :confused:
  13. leftcoast
    haha.....sorry
    - feeble attempt @ earth humor.
    it's Miles Davis - All Blues.
    probably from Kind of Blue.
    One of my all time fav's.
  14. loufu
    loufu New Member
