Leaking Radiator
Discussion in 'Mechanics Garage' started by Superceptor02, Aug 30, 2008.
  1. Superceptor02
    Superceptor02 New Member
    Tennessee
    Got to work Friday and noticed that my bike was leaking some antifreeze. Got home thought that it was a hose clap turned out to be the radiator. Should I try to have it fix if possible or just fork out the cash and by a new one? Anyone know about how much a new one will run?
  2. maddog
    maddog New Member
    Idaho
    Are you positive it's actually the radiator which is leaking?
    If so, I would think that would be way out of the norm.
    Has the bike been dropped or otherwise damaged, which might lead to a leak?
    You might clean the bike thoroughly, after removing fairings, let dry, start and warm up the engine and re-check all hose clamps (there'a a bunch).
    I've got well over 150,000 miles between a 4th and 5th gen VFR with no problems from the radiators.
    A quality radiator shop, emphasis on quality, can probably fix it for much less than the cost of new. Another fix would be to check out m/c salvage places, where you might find one in serviceable condition.
    Just noticed you're in Tenn., probably some racecar shops nearby which may lead you to a good rad repair shop.
  3. Superceptor02
    Tennessee
    Thanks for the info I have never dropped the bike and I checked a lot of the hose clamps. But I will double check to make sure.
