LCD light is out
Discussion in 'Introductions' started by ebear98VFR, Jul 21, 2006.
  1. ebear98VFR
    ebear98VFR New Member
    San Diego
    Does anyone know how to fix this..When I ride at night my LCD screen light is out so I can Not see it at night..the screen works and is fine in the day all the read outs still come up. Just no backlight. Thanks New Member-E bear
  2. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    I was looking at the diagram on bikebandit.com and that looks to be a sealed unit. Not being too familiar with the workings of LCD, I am thinking something may have burned out. But check simple things first like the connection it might be loose or one of the connectors might be corroded causing a bad connection. Bikebandit lists the unit for $366.49. Ouch. If you have a service manual it might help you troubleshoot the issue. You can get one thru a dealer or Helm Inc.
  3. bear
    bear New Member
    Ajax, ON
    take the nose fairing off, and replace the little light bulbs. Pretty sure there is one on the top, and one on the bottom. Just a standard "peanut" bulb will work (194).
  4. WhiteKnight
    London, Ky
    If I was wrong about the LCD unit, I apologize. It was hard to tell from the online fische if there was a bulb behind the LCD unit and the unit itself looks to be sealed with no way to fix backlighting.
