Knocking sound and feel on 91mod 750
Discussion in 'Mechanics Garage' started by Mads Oliver Jenssen, May 23, 2024.
  1. Mads Oliver Jenssen
    Mads Oliver Jenssen New Member
    Norway
    Hi!
    Please listen to the sound from my video
    https://www.jottacloud.com/share/eouokk8tb11s
    Especially around 37-39 sec in the video, you can hear a metalic knocing sound.
    It can be heard while driving, especially at lower rews, but I guess that is mostly becouse the higher rews mask out the sound both because the general motor sound is higher and the speed of the sounds are more high freequent.
    Is this bad?
  2. Terry Smith
    That sounds like clutch rattle to me, and that is neither a concern or unusual. The idle sounds quite unsteady and suggests the carbs might need to be balanced, which should smooth out the idle and maybe reduce the knock. Certainly the rest of the engine (aside from the knock) sounds fantastic.
  3. ridervfr
    Belgium
    Whats the mileage on the unit? When was the last time you had the carbs synched? Out of sync carbs can sound like that, the slides rattle around too.
  4. Mads Oliver Jenssen
    Norway
    Actually it was the chain that was very loose that caused the worst knocking sound.
    After I tightened it, it went away. I guess even when it stood still the motor vibrations made it knock into everything.
    However now I can also hear the carb issue and also feel a bit uneven idle that your fine tuned ears heard long before me
    Also i can hear some "poppopop" (there is probably a word for that) from the motor after rewing and than letting it drop fast in rpm. Probably also a sign that i need to adjust the carbs?
    Sent fra min Pixel 7 via Tapatalk
  5. ridervfr
    Belgium
    If you were my neighbor, I would do it for free for you. :mech:
