K&N, rubber cut = smooter Vtec?
Discussion in '6th Generation 2002-2013' started by fuji1, Mar 3, 2008.
  1. fuji1
    fuji1 New Member
    Guys,
    Over the winter I added a K&N filter and while I was there I cut the rubber boot in the air box above the air cleaner. I didn't cut all the way just made it so the air flow was less restricted (if that is possible).
    Now riding the bike today it seems the transition into Vtec is smoother. Less abrupt more like a power band than down shifting. In the past when the Vtec came on there was no doubt it was there but today it seemed smoother.
    Is it me or has anyone else noticed this.
    Joe
  2. PARedVFRRider
    PARedVFRRider New Member
    Skippack, Pennsylvannia
    I think you are talking about the Airbox snorkle, yes? If so, I've actually pulled that out of the airbox and I have noticed a similar smoother progression. I also plugged the flapper valve hose at the same time.
  3. fuji1
    fuji1 New Member
    Yes the air box snorkel thing. I cut the bottom half and the edges to smooth things. If it has some effect I couldn't say at all. But the Vtec transition is smoother with that and the K&N add.
    Hey I'm happy, Thanks,
    Joe
  4. elf800
    elf800 Banned
    dallas
    paredvfrrider did you cut the hose and plug it? or could it be pinched off via ziptie?? was wondering how that was done seems like the riders mod their bikes exhuast pc3 o2 end up doing that as well any info i would appreciate elf800 contact me if you can
