K&n filter
Discussion in 'General VFR Discussions' started by duccmann, Nov 16, 2012.
  1. duccmann
    Quick question-------- on replacing my oem filter with a K&N. It said to remove the o ring from lid and base ---There was either. Put the filter in, made sure it was seated with the lid and bottom base, snugged it up with the screws and now there is a 1/16 to 1/8 of a gap between the base and lid. The oem was a hard plastic and the K&N is rubber ,so I think its OK plus the tank went down with no problem. Just was woundering if that was normal for this kind of filter. Thanks :confused:
  2. taylor65
    taylor65 New Member
    florence, al.
    I have a k&n and I still have both of my o-rings. I never had the oem filter so I don't know about the gap. Mine has about the same amount of gap from being flush as well. I wouldn't worry about it so long as the filter is in the grooves and snug with no air gaps. Hope I helped some anyway
  3. duccmann
    Thanks Taylor
  4. zoom-zoom
    zoom-zoom Member
    BC, Canada
    I can remember putting a K & N filter on my 97 VFR a few years back and noticing the gap was larger as well. If I recall, the flange on the K&N filter was a tad bit thicker than the stock filter.
  5. duccmann
    Thanks zoom zoom. That seems the norm I guess
  6. Valentino Robbie
    Valentino Robbie New Member
    SE London
    I have a K&N in my VFR 2000 and yes you absolutely do take the rubber o ring thing out. All bikes I have put K&N air filters in, the rubber ring needed removing.
    As long as the cover is on nice and tight it wont leak through thanks to the million and one, mile long screws holding her down.
