Just picked up an 85 vf500 lend me your thoughts
Discussion in '1st & 2nd Generation 1983-1989' started by 1bd85vf500, Jan 28, 2009.
  1. 1bd85vf500
    1bd85vf500 New Member
    I picked up an 85 vf500f interceptor a couple weeks ago from a tow yard for $250. Hasn't been registered since 2000.
    Bad things:
    wouldn't idle
    rear shock needs some love
    front brake master and lever missing
    rear brakes hammered
    tow yard busted ignition switch and fuel cap with screw driver as they had no key
    all lights not working
    exhaust hacked up from 4-2 to 4-1 with lots of nasty welds
    What I've done so far:
    took the carbs apart idle jets were clogged and carbs were rather dirty. I picked up another set in great shape and threw them in
    replaced spark plugs and wires
    replaced front brake system
    replaced rear rotor and pads
    got all the lights working
    got a full vance and hines dual exhaust for the bike and threw that on
    So now the bike starts and idles but only runs on 3 cylinders. It has spark and fuel on the cylinder its not running on so I'm guessing the valves need to be adjusted. Does this sound right? any other ideas? how often should the valves be adjusted on this bike?
    Also the rear shock has definatly had better days I called the dealer and the seal is NLA so I was just going to add some oil to it but don't know how much to add as I don't know how much is left in it. Was thinking of adding 25cc at a time and test is this a bad idea?
    I've also herd that these bikes have issues with the cam chain tensioner is there anything I should replace for that right away? How do I avoid these problems.
    Any other info on what to look out for and how to get this bike running top notch would be great. Thanks
  2. Pcohen
    Pcohen New Member
    jonesboro, arkansas
    That sounds like an OK deal for $250 considering it was in somewhat of a running condition.
    I have 2 vf500's and I have had similar problems with one cylinder not firing and on my bike it was a compression issue. I have also replaced the cam chain tensioners in one motor but could not hear a difference in the noise between the two. I adjust the valves on mine at the start of every season and that seems to be adequate.
    The rear shock is an air shock so look around where the coolant tank is and you will see a little valve that looks like a tire stem and you can pump a little air into it with a bicycle pump. The rear shock on these are crap and I have heard of people replacing them with other honda shocks but I am not sure what will fit. It might take some rigging.
  3. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    Honestly, I'd tell you not to bother. Those stock shocks are really prone to failure and once they go bad there is no way to bring them back. Take a look at my site, I show some stuff in the How To section that might interest you. The modified rear shock page shows the details on what I've come up with. So far I've not found anything better to solve the problem of failed rear shocks.
