Just ordered a shrai LFX 18A1-BS12 light weight battery!
Discussion in 'Mechanics Garage' started by sunofwolf, Jun 24, 2014.
  1. sunofwolf
    sunofwolf New Member
    This battery weighs 2 pounds, the amg battery 8 pounds. Seems like a great way to save some weight and also maybe a better charging system. I will take the Shorai out when it gets cold. From what I read its actually a 6amp battery when cold not a 18amp-it should be plenty in warm weather-well I got a month to test it or send back.:stickhorse::spy::bluesbros::evil:
  2. TNRabbit
    TNRabbit New Member
    Woodford, VA
    Perhaps the lighter weight will assist you in not dropping your bike so much~
  3. sunofwolf
    It should help a bit, 5.8 pounds it saves plus its a 18ah battery not 11 ah like the the amg. The hardware for the bags added about 5 pounds. That's a 1% reduction in weight, but its fairly high up ,so it would feel like more weight was lost.
  4. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Ooh, snap.
  5. MrSleep
    MrSleep New Member
    Verdigris, Oklahoma
    I put a Shorai battery in my Sportsman 500 and even when the garage was 35 degrees F it started just fine with no signs of slowing down. When the VFR needs a new battery I'll be getting one for it. Shorai highly recomends that your charging system is in tip top shape!
  6. sunofwolf
    I think ,this is a very cool battery and might help the bike start up a bit faster because its rated at 18ah instead of stock amg of 12ah that's 1/3 more extra juice. and the loss of 5.8 pounds is nice.:gun3::banana::bluesbros:
  7. carlgustav
    carlgustav New Member
    Heart of Dixie
    Have had a Shorai in my VFR since last Sept. No problems so far (including over winter) and I don't use any external charger on it yet.
    ACE
  8. sunofwolf
    Shoria being delivered today, 2.2 pounds, Lets see what this device does!:chaingun::stickhorse::flame::banana::vader:
  9. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    It's a battery, it starts your bike. What else is it supposed to do?
  10. sunofwolf
    I think this battery could fly in a plane its so light, but what does it do-saves 5.8 pounds has 33% more starting power-is smaller and holds its charge for a year-that's about it!:saturn:
  11. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Right now from what I understand, the jury is still out on its overall longevity. See who it works in 3 years after some neglect, cold weather, hot weather, and vibration take their toll.
    As far as the weight, my body weight fluctuates 5-7 lbs. easily. I'm still undecided whether it's worth the money. I've heard of a couple that bit the dust pretty quickly, but they could have been flukes.
    33% more starting power. Mine does a fine job of starting the bike, what exactly will 33% more starting power do? Start it 33% faster? Like I said AFAIC the jury is still out.
  12. sunofwolf
    My understanding is shoria had some duds and fixed them-like bad terminals. Any way three years is better than my amg was only 0ne year. I use amg in cold weather and take shoria out then. But above 45 degrees I am guess the battery should work. Who knows?
  13. sunofwolf
    Got battery-Looks very cool-came with 60% charged-just drop in and go for a ride to charge it up. On other had I can use my battery tender. If it works a ok mod.
  14. sunofwolf
    I don't have a shoria battery charger but you can use a battery tender Jr charges at .05volts, so I put it on charging with the Deltron. It is suppose to be charged at 60%, but I think it is a good idea to throw some low volts on it. This battery retail for $189-I paid $145. One other note buy the shoria LFX 19A1-BS12 for a extra 1amp-that adds the retail price to $200-same weight as the LFX 18A1-BS12. When green Light comes on pull the plug.:kiwi-fruit:
  15. sunofwolf
    no one sells the 19 amp version except shoria, so the $145 is the best deal.
  16. sunofwolf
    this shoria battery is really good so far-I took off about 7 pounds, battery lose 5.8 pds, cowl removed-1 pd, refectors on the side 8oz, battery tender wire removed -8oz= around less than 8pds taken off. I noticed a big difference in handling. The shoria also is 33% more powerful than the stock type by 33% and the lights came on very strong. I don't need a battery tender unless it real cold.:dance::funky::hat::ranger: Next mod the pipercross air filter being shipped from London.
  17. sunofwolf
