Just finished my Tstat replacement today.
Discussion in 'General VFR Discussions' started by Junyr, Apr 19, 2010.
  1. Junyr
    Junyr New Member
    Des Moines, Iowa, United States
    First let me say thanks to Elwray for the text support on the change when I was getting stuck.
    Now, let me say what a trainwreck that is to change. I don't know if I want to strangle a Honda engineer or two or if I have way more respect for their ingenuity.
    Anyway, all went well. The old thermostat wasn't stuck open or corroded when I took it out but it the copper/brass colored cylinter inside of the big spring has some very shiney scratches where clearly it was binding somehow.
    I did a drain, flush with distilled water/prestone cooling system cleaner, drain, refill and rinse with pure distilled water, drain and refill with proper coolant mixture.
    Once it was all back together and after a short MPG test (only 40 miles on a full fresh tank) I increased my fuel economy from 23 MPG to 30. Now I'll run this tank fully down and get a better reading. IN those 40 miles I had a bit of in town, about 20 miles of interstate and a couple of WOT interstate entry runs along with one country road run to about 110mph...
    So far I'm very happy with the results and more happy that I had no leaks in the system after it was assembled. I hope to never have to do that again.
    Let me add the satisfaction of doing a job successfully yourself and saving about $300 dollars in the process.
    Chip
    JUST to remind you what kind of "progress" Honda has made over the years: on gen 1 and 2 bikes the thermostat can be changed in less than 10 minutes after removing and replacing 3 or 4 small bolts......
  3. captb
    captb New Member
    Must have hired some GM Engineers at Honda R&D, when I worked at Chevy if a starter failed (or most other engine problems) on a Corvette ZR1 we had to ship the engine back to GM for repair. The starter was in the engine under the plenum with a lot of other troublesome goodies.
